How to establish whether loading effect is caused by opamp?
danesh
Full Member level 3
hi,
recently i have loading effect on the circuit i design which connects to electrect mic. Some of my fend suggested it might be due to the op amp which cant handle the load. In the first place hw do i determine wether it can or not?
Re: op slelection
I don't know if this helped but i think if your op amp current cannot support the load then the load will simply not work... you can check ur datasheets for your op amp ? apologize if it doesn't help.
