How to establish a wireless communication between two micro controllers (89C51)?
narithota
Full Member level 1
Hai
I did communication between two micro controller using RS-232.
Now I want do wire less communication between two micro controllers.
How to do wire less communication between two micro controllers (89C51).
Distance between two micro controllers is 5 meters.
In my project receiver and transmitter not see each other,
Transmitter is at fixed position but receiver rotates 360 degrees with in the 5 meters range.
Any readymade transmitter and receiver IC s are available.
Can you suggest hardware for this project?
Thanks
Regards
Naresh
Remote
you can use an encoder ic "ht12a" to encode data and send it to ir led
then you can receive the data by ir detector which sends the data to ir decoder ic"ht12d" to decode it
for more help go to this sitew :
http://www.rentron.com/Fire-Stick-II.htm
you will find the schematic forthe transmitter and thereceiver circuits and pdf files for the datasheets of the parts used
and if you havent enough time to do this circuit u can buy it from the above site
Re: Remote
One other option are 433MHz RF (el-cheapo) modules ..
This one is the transmitter:
This one is the receiver:
For the distance of <5m they should work even without 1/4λ antennas - just a tiny piece of wire should do ..
Regards,
IanP
Re: Remote
Thanks for reply
Here I need RF transmitter and receiver with 4 channels.
My doubt is from micro controller, data we have to give directly to the transmitter
or we have to use any hard ware between micro controller and transmitter.
Suggest a transmitter and receiver chips which is compatible with micro controller.
Regards
Naresh
Re: Remote
Please refer these documents and you will find your self doubtless.
  • stt-433_1080.pdf
  • str-433_1060.pdf
