I have the following preamp circuit built but the gain of the ecm is not so good. I have to speak loudly and that to very close to the ecm. can anyone suggest how to enhance its gain? the diagram is dully attached.
Do you have this Pre-Amp Connected to a POWER AMP?
This Pre-Amp Can't drive a Speaker without a Power Amplifier.
The output level of an electret mic is about the same as from a dynamic or most other types of mic.
The circuit is found on a few sites in Google when looking for the Philips 3-wires electret mic. Its gain should be high enough for the circuit to feed a power amplifier or recorder that has a fairly high input impedance. What do you connect it to?
DO NOT bypass R3 with a capacitor because then the gain, noise and distortion will be much too high. Instead reduce the value of R3 until the gain is high enough and the noise and distortion are not too high.
It is designed to drive a high impedance. What is the input impedance of your 1W amplifier?Yes it is connected through a 1w RMS Power Amplifier with a .5 watt speaker.
Simply replace the 47 ohms with 22 ohms, 10 ohms or 4.7 ohms until the gain is high enough and the noise and distortion are not too high.Can I add a variable resistor in place of R3? if so then what'll be the value??
it is designed to drive a high impedance. What is the input impedance of your 1w amplifier?
If you increase the gain and the mic can hear the speaker then you will have acoustical feedback howling.
