How to edit the *.db lib file?
phuang
Junior Member level 1
Dear all,
Can I edit the *.db lib file, or change it back to *.lib format?
I got a .db lib, but there are some warning. I want to edit the lib file, but I don't know how, please help me.
Thanks!
phuang
phuang
waiting for your help, thanks.
rca
Marin
the db file is a generated format for Synopsys.
the lib is the ASCII view of this db file.
You can only modify the lib, and recompile it with lc_shell (special license for it requires) to otain the db file.
funtion of the warning, you do not need to change the lib and specialy if the lib/db are provide by an external provider, you must ask to your provider to modify the files.
    phuang
kumar_eee
Advanced Member level 3
Bangalore,India
You can't edit the .db files. You can modify the .lib files & read it in Library Compiler and write out the .db files.
    phuang
phuang
thank rca and kumar_eee!
So it means there in only one direction between .lib file and .db file, --> we can only compile .lib file into .db file.
I see, thanks.
