since msp430 is a mixed signal processor can we use the external analog values (values from sensor) directly in program without converting it into digital?
Then what is meant by mixed signal processing ?
Are you trying to download a new program or extract an existing program from the MSP430FG4618?
You can use the MSP430 LaunchPad as both a programmer and debugger.
MSP430 LaunchPad Value Line Development kit
Depending on whether any code protection has been activated, you may be able extract/dump existing binary from the device.
BigDog
Do you mean using launchpad to program the 4618?
Launchpad can program only SBW devices and if I remember
correctly, FG4618 is not an SBW device. It has to be programmed with a regular JTAG interface. I may be wrong on
this one, so just in case... please verify!
I think SBW appeared with the 2x series.
whether msp430-jtag alone is enough to program header board for msp430f449.
MSP430-JTAG is100% compliant to Texas Instruments MSP430-FET, so it will works with any package which supports TI-MSP430-FET
program all MSP430Fxxx flash microcontrollers (note: parallel port JTAG doesn't support Spy-Bi-Wire devices as timing from parallel port can't meet programming specs)
uses TI standard 2x7 pin JTAG connector
I have IAR workbench IDE for msp430
what is the difference between the above three JTAG?
out of the three which one you suggest me to bye?
