How to dump fsdb in ncsim?
dreamscome
Junior Member level 2
ncsim fsdb
I was trying to dump fsdb in ncsim by using the cmd "ncverilog +loadpli1=${DEB_PLI_FILE}:debpli_boot xxx"
But I got this error:
ERROR: ACC PLISVG
The routine acc_object_of_type() cannot be applied to an object of type <unknown>. Use the SystemVerilog VPI instead (Clause 27, IEEE Std 1800-2005).
Anyone has seen this error before? How to fix it?
ncverilog fsdb
Have you tried...
initial
   begin
      $fsdbDumpfile("padtestt.fsdb");
      $fsdbDumpvars;
   end
ncsim dump fsdb
Yes, I tried this. I guess it's some kind of PLI setup error.
ncverilog dump fsdb
From the error message it looks like you have some SystemVerilog code and are trying to dump them using $fsdb*. If so, make sure you use the latest NC & Novas tools. Read:
Specifically you need to use:
$NOVAS_HOME/share/PLI/nc54/<platform>/nc_shared/*.so file for linking.
HTH
Ajeetha, CVC
www.noveldv.com
    dreamscome
fsdb dump in ncverilog
Cool. This solved my problem.
Thanks man...
HTH
Ajeetha, CVC
www.noveldv.com
how to dump fsdb in ncverilog
You have to load the PLI at the beginning of your simulation.. Refer to help of novas..
