how to drive a large capacitive load?
katrin
Full Member level 1
a circuit output is going to drive the next stage circuit which is a large capacitive load of the previous stage(please see the simplified picture below)
In order to drive this large capacitive load, should I consider about increasing the current flowing in the previous circuit or should I increase the size of the transistors Q1 and Q2?
In general, in order to drive a large capacitive load, how can I optimize the circuit?
darkk
Member level 3
Put a super buffer between the 1st stage(q1/q2) and the loading cap.
    katrin
smoked
Junior Member level 2
If you are driving the capacitive load with an inverter which is seen from your schematic, rather than using a single inverter use chain of inverters namely "tapered buffer".
    katrin
supreet_95
Member level 3
bangalore
U will have to increase the current and correspondingly the size of transistors also, which will increase the input loading of that stage, u may have to add another stage before that to run it.
2 or 3 stage buffers can run a large capacitive load.
Hope this helps.
    katrin
katrin
Full Member level 1
normally, which kind of buffer can be used here, in order to obtain an output signal which is the same as the buffer input?
smoked
You can use a simple OTA with a unity gain feedback. Determine the current based on output capacitance and bandwith requirements of the signal.
    katrin
supreet_95
Member level 3
bangalore
We can use two stage, differential to single ended buffer with 2nd stage being inverter with active load (with compensation).
Added after 41 seconds:
We can then connect the differential buffer in unity gain buffer configuration.
    katrin
