How to draw slot antenna in HFSS
mouek_1989
Newbie level 1
Indonesia
Does anyone have the experience of designing a slot antenna in HFSS.
The structure is so complicated that takes a great effor to draw the lines. So, does anyone know how to draw them in HFSS or how to import a layout from other easily-used softwares?
Thanks in advance.
Very HappyVery Happy
shmily0447
You can try co-design your slot antenna with Ansoft Designer, in which you have to build your own library, and then you can export the Designer schematic into HFSS 3D structure.
Or you can use HFSS-Matlab api, which can be found from google.
But theses tools are not precise and accurate and also take a long time to learn to use and build the lib.
So, I suggest just use the HFSS to draw your antenna. With further operation of rotate, duplicate you can reach a very complicated model.
