How to draw layout of capacitor
ramana459
Junior Member level 3
how to draw a capacitor
hi, I am doing CMOS based 2 stage opamp,
I want to draw the layout of compensation capacitor.
can any one help to me to draw the layout..
with regards,
Ramana
how do we layout a capasitors
with regards,
Ramana
no need to have special care on the layout of this capacitor. Just use the available space after layout the transistors to draw the capacitor. Its value is not critical, since due to corners the spread on its value will be big.
Bastos
hto draw a cap
but it is giving error while doing LVS, so Can you tell me any other method or how to draw layout of capacitor
how to draw capacitor
What kind of error. Does not recognize the capacitor, or is due to having different area perimeter in schematic from layout. Use the same values in schematic that you have in layout.
Bastos
how do we lay out a capacitor?
If you are using Cadence layout, use a square M2, then a smaller square of "res_id" and then use the same size "M1" , then extract to check the capacitor. The better way of capacitor design is centroid layout method.
what is the difference between MiM, Mom, poly capacitors ??
Thanks
