torbai
Member level 3
- Joined
- Nov 15, 2011
- Messages
- 67
- Helped
- 15
- Reputation
- 30
- Reaction score
- 13
- Trophy points
- 1,288
- Location
- Harbin,China
- Activity points
- 1,744
How to draw board outline, which could be exported to gerber file, in ADS?
Should I use a rectangle to represent the board, or use wires to draw the outline?You can draw PCB outline working in ADS layout.
If ' cond ' is your metal layer,select say 'default' layer
to mark your PCB boundary.
I'm sorry, I still don't get it...If you are making PCB boundary to mark board edges for cutting the PCB
after fabrication, you can draw four corners in metal layer itself.
If you want to pre-define your PCB size while making a layout,then draw a
Rectangle in some other layer.
