How to download a hex file into 8051's rom?
Sumit Kumar Aggarwal
Newbie level 1
hi
i wanted to know that how to download a hex file into 8051's rom. Is there a way doing it, using just a serial port of a pc.
hr_rezaee
Advanced Member level 3
Iran-Mashhad
loading hex file
Hi
I don't think using just serial port.
I know you can program it by using parallel port.
search the eda board you can find many info.
regards
Abu Ammora
Full Member level 2
East Coast
Re: loading hex file
For Any Microcontroller you must have a Programmar + suitable program that burn/download your hex file int Microcontroller ,
For ex : in PIC Miceocontrollers Familly i use ICPROG
bobcat1
Hi
To do so you will need a Bootstarp loader, or a rom monitor program running
All the best
BObi
louisnells
Full Member level 4
You have to use a program for that check **broken link removed**.
Also you need a hardware burner for loading. Check the attachment.
richie_moses
Newbie level 1
Hi
Actually I depends on the Processor you are using certain advanced 8051 series with internal flash provide certain standard interfaces like SPI.
AT89S8252 uses this i have used this you can also download the PRogrammer for it its free for download
sat22
Newbie level 6
If you use a mcu with ISP feature (In System Program), you can download a hex file via serial port. You can do that with the software that the Manufacter have for you to download (free), for example:
if you use a mcu from ATMEL, you can download "flip" programmer, from ATMEL's site;
if you use a mcu from PHILIPS, you can download "Flash Magic" programmer from "h**p://www.esacademy.com/software/flashmagic/";
this 2, i had worked whith and are very easy to work whith.
regards.
