How to do Viterbi decoding in Matlab
bee
Full Member level 2
Could any one plz tell me abt the veterbi decoign and its malab code?
waiting....
rmreddy
Member level 3
Re: Vetrbi Decoding ?
hi,
actually there is an inbuilt function - vitdec , which accepts the code to be decoded, traceback length, trellis structure, and two more input fields that decides the intial state of the shift register and decoding type ...
but if you want the code for this function, then its highly complicated, rather than understanding that code, you can come up with a better code, if at all u have comletely understood how a viterbi decoder works ...
cheers ..
    bee
bee
Full Member level 2
would u plz give me any document from which i get a clear idea abt this veterbi decoding ?
waitign....
tigerajs
Member level 3
you can get it through google
anwei7208
Junior Member level 1
You need Matlab comm toolbox to use its viterbi decoder. There are some free c/c++ code online. Do some googling.
ha_wasfy
Member level 1
Vetrbi Decoding ?
Bee are you a student in Alexandria faculty of engineering?.........Just a question :)
bangash
Member level 5
London
Vetrbi Decoding ?
its present in simulink model of matlab.
bee
Full Member level 2
no i am not
azim.fahad
Vetrbi Decoding ?
Infact matlab help itself has very good starting info availabe about convolutiona coder and vitebi decoding....
& in 2006(a) and above version- vitdec - command become very poweful with addition of code puncturing thing etc......
ilovepachaya
Newbie level 1
waiting....
maybe it's useful for you
    V
xakker
Member level 2
it is actually a soft decision decoding where by demodulator tells its confidence level too for his decision which in turn can be used in trellis
omhr
Newbie level 6
Vetrbi Decoding ?
does the vitdec() function has any flexibility in using the "Euclidean Distance" as a branch metric calculation?
toughest
Newbie level 1
Vetrbi Decoding ?
bee might be from istanbul technical university:p
mannooha
peace upon you
my grdution project is in fixed wimax and i use vetrbi decoding in my implementation but when i use the vitdec function on matlab i found variable called traceback depth and i found that it is equal to 5 times the constrain length for rate 1/2.
but i couldn't find the value of this variable for other rates .
plz can any one help me??
