How to do manual fabrication of Antenna in copper PCB board double side?
satishvel
Newbie level 2
I have the required materials for fabrication (PCB board,Sma connectors)i am doing the project in ADS-2014 layout window but the problem is after the simulation i have taken the printout of the layout design, the size of the patch antenna is large as in printed document my size of antenna is 50x50mm and another thing is what kind of sheets should be used for printing the antenna design(A4 or OHP sheet or something else)
aniakhan
Full Member level 2
satish, can you help me in understanding that if you will get the print then what will be next step of fabricating antenna?that is how will you fabricate it? i have no idea about it.please tell me, you will use electroplating for fabrication?
