[SOLVED] How to do integer divison rounding to closest integer, vhdl synthesizable code?
nicklas_a74
Member level 1
Hi
I want to have generic input values e.g. a and b what are used to initialize a
constant by e.g. constant c:= a/b; However due to the division the
correct answer could be 4.6 but it’s rounded down to closest integer 4 as default.
How to being able to initialize the c and have a rounding to closest integer 5?
The code should be synthesizable and use the standard libraries. Is there a
way to do this without fixedpoint or special math library?
std_match
Sweden
Try c:= a/b + 0.5;
It can be more complicated if negative values are involved.
kripacharya
Banned
New Delhi
The simple trick is to add half the divisor to the dividend before doing the division.
So basically you should do c:= ( a + b/2 ) / b
TrickyDicky
Advanced Member level 5
If it is only a generic or constant, you can use the real type:
c := integer( real(a)/real(b) );
real -> integer conversion always rounds to nearest.
nicklas_a74
Member level 1
Thank you for the valuable suggestions
