The fuzzyTECH MCU Pack features assembly code generation for a variety of microcontroller families. This assembly code is highly optimized for the respective microcontrollers and allows for the most efficient implementation possible. All fuzzyTECH MCU Editions can generate C code, too.
thank you for all especially for deepu_ttc....
i hope it useful for me...
BTW...can ATMEL microcontroller like ATmega16 or 32 be used for fuzzy implementation?....
isn't fuzzy programming on microcontroller spent a lot of computation time?...
could Fuzzy logic algorithm be used for real time application?....
as far as i know fuzzy logic can be implemented on mcu especially on 16/32 bit cores. but comming to real time implementation i dont the concept at all
I think that an ATmega16 or 32 can be used for fuzzy implementation perfectly.
The site w*w.fuzzytech.com in section "Products/fuzzyTECH Editions/Benchmarks" contains a table that shows the benchmark results for typical hardware platforms.
you can design fuzzy logic control and simulate on matlab then make data table from matlab and use lookup table for caluate output by microcontroller this method is fast and save your memory
