how to do division in VHDL
xilinx1001
Member level 3
Member level 3
How can I do division in VHDL?
Is there any other method of doing division in VHDL other than right shifting?
Regards
xilinx1001
Repeated subtraction is one method i can think of. There are a lot of dedicated algorithms.
Look up tables too is possible.
Thanks for ur reply
Can ou please give me the link for division by repeated substraction in VHDL
Regards
xilinx1001
  • If you have newer version of Xilinx,you can use numeric_std package & use '/' operator. The division operator is recognized by ieee.numeric_std.I am not sure if you can use this package with older versions of Xilinx.
  • numeric_std is valid only if your inputs are of datatypes UNSIGNED/SIGNED/NATURAL/ INTEGER.
  • With the old synopsys libraries, division is however suppported for integer datatype, so maybe you can conversions if that is simple for you.
Thanks for your reply. I am using older version of xilinx. I need to do use a number like 2500000 for division. This number exceeds integer range. How can I use division for this number without initializing it as integer?
Regards
Vivek Alaparthi
