How to do dc sweep 2 variables input in cadence spectre
tompham
Full Member level 2
usa
Hi all
Anyone know how to run cadence spectre with sweeping 2 input variables? Let say sweep vgs and vds of nmos
Thank your
Use nested sweep analysis.
swp_vds sweep param=vds start=0 stop=1.5 step=0.1 {
    swp_vgs sweep param=vgs start=0 stop=0.5 step=0.1 {
See result "spectre -h sweep".
Hi pancho_hideboo
Where I can add the lines you mention? In input.scs? and after adding the lines I need to run not to netlist and run?
Cadence Spectre have multiple sweep analyses using sweep analysis.
See "spectre -h dc" and "spectre -h sweep".
If you run Spectre simulation from Unix Command line such as "spectre input.scs".
You can use following analysis statement.
    swp_vgs dc param=vgs start=0 stop=0.5 step=0.1 {
However it can not be available directly, if you run Spectre from Cadence ADE.
You can specify vgs sweep as dc native sweep from ADE.
However you can not set sweep analysis for vds from ADE.
Instead you can use Parametric Analysis for vds sweep.
This is ADE function not Spectre function.
ADE's Ocean generates input.scs with changing vds.
This is equivalent to the following.
spectre input_vds1.scs
spectre input_vds2.scs
spectre input_vds_N.scs
You can not use full ability of Spectre if you run it from ADE.
Hello
Is there quick start guide documents to learn full ability of spectre?
tnx
Hello pancho
I googled for
Virtuoso Spectre Circuit Simulator and Accelerated Parallel Simulator User Guide
, and I found:
Spectre Circuit Simulator User Guide
which have 334 pages. Is it what you have mentioned?
Every time I had to do nested loops, I used the Parametric
Analysis tool and a DC OP. You may not find any value in
a continuous sweep. You -could- run Spectre native or
under Ocean, but if you are in the graphical environment
maybe you'd rather get to the outcome and skip the voyage
of discovery. Unless said voyage is the point of it all.
