How to do a minimum voltage select circuit?
harrytrinh
Member level 2
Minimum select circuit!
Hello every one,
I am designing the circuit to chose the minimum. What is best way to do it? Thank alot!
Re: Minimum select circuit!
Minimum current?
No. That is minimum voltage.
You can do it by two diode. connect anodes through a resistor to the +Vcc supply. And use each cathode as a input. If you want to eliminate diode voltage drop, use buffer amplifier.
Greetings
Thanks alot! I got it.
