How to divide XTAL Frequency?
Rooftop
Full Member level 2
how to convert xtal pll
Hi everyone,
i need about 7,37 MHz and 3,6864 MHz but i only have 14,74 MHz here. My question is can i use simple counter to generate them because 7,37 Mhz is only half of my Xtal and 3,6864 is only about a quarter of my xtal?
If anyone ever experienced this problem please give me some advice and some schematic. Thanks for your attention
Best Regards
xtal divide
use ordinary digital logic counters. A 74HC7474 can divide by two by putting the Qnot output back to the D input. If you oscillator output is a small sine wave, use a high speed comparator to convert it to logic levels.
    Rooftop
74hc7474
Thanks for the repply
So i just need counter right? Did i need some PLL or another? my plan is using GAL because i have some spare of it and i want to connect the output to my AVR,so what configuration of clock for the AVR that i should use?.By the way thanks again for the repply.
Best regards
frequency from xtal
Hi
Use a simple deced counter - but remembe etch devide section on the counter need one F/F - limited resource on a GAL device
For instance if you need to divide by 4 you will need 4 F/F from the GAL
All the best
Bobi
