How to display the spectrum of power amplifier in ADS( technology TSMC 180 nm)
Hi;
I would like to display the spectrum of ultra wideband amlpifier in CMOS TSMC 180 nm. How can i found tutorial explain clearly the process : simulation of spectral power of amplifier which is clear without using some template. I need just a clear and simple tutorial.
Thank you
Re: How to display the spectrum of power amplifier in ADS( technology TSMC 180 nm)
Hi hanen88,
The output frequency spectrum of the UWB amplifier is a windowed Fast Fourier Transform (FFT) of the output signal.
The spectrum will show the frequency outputs as peaks at the frequency with the power contained at each frequency.
