I have a 3D structure in LiNbO3. An antenna is positioned on the structure. I want to display a cut of the electric field on a plane trasverse the structure.
if in the hfss system,you can define a cut plane before the simulation,after you finish the simulation,then display the electromagnetic distributated field in this cut plane
You'll need to set up an 'infinite sphere' for far or near field under radiation. The 3d plot is pretty easy to get as a report but have a look at the coordinate sys on the 3d plot - the phi and theta are reversed. Something to keep in mind when you want a specific cut.
