er.akhilkumar
Full Member level 2
Hello All,
I am facing problem in disabling an assertion written in RTL by using $assert_off or $assert_kill in System verilog class.
the example given on internet is as following:
$assert_off(1,testbench_top.assertion_name);
The above code is valid for the assertions written at testbench top. If I want to disable the assertion written at RTL level. How can I disable them?
I have written the code as following for disabling the RTL assertions but it reports ncsim error:
$assert_off(1,tb_top.design_top:assertion_name);
I have also tried putting the heirarchy as string but failed.
Have you got any solution? I am using OVM based system verilog testbench and RTL written in VHDL.
Thanx.
Thanx.
