Register Log in
How to disable the grub to uninstall Linux from a partition?
nafaiz
Member level 5
Malaysia
hie,
i have installed linux as another OS in a different partition and i want to uninstall it now.
The problem was that how to disable the grub at the beginning of turning on the computer. If i dont disable it and continue with uninstallation, i heard that i might not be able to log in to windows again. Does anyone have experienced this before and have found the solutions? I'm new to linux.
Thanks.
regards,
nafaiz
Hughes
Advanced Member level 3
Re: uninstall linux
You can boot the computer into ms-dos and run:
fdisk /mbr
dipal_z
Full Member level 5
India
uninstall linux
If you are using windows XP you need to use fixmbr command instead of fdisk /mdr.
Once you are done with this activity reboot your computer and ensure that you don't get grub menu again but it should directly boot into windows. If everything goes fine you can delete linux partitions safely.
    nafaiz
Anno
South Africa
uninstall linux
dipal_z's option works best if you got XP running as the other OS. but Why would you want to uninstall linux?? :'(
nafaiz
Member level 5
Malaysia
Re: uninstall linux
rite now i'm short of ram and hard disk. 2 OS makes things worst. that's why i need to uninstall at least one. my work use windows more. that's why i have to uninstall linux.
Added after 4 minutes:
sorry if this question is silly. i'm not familiar with the command. how do i actually use this fixmbr command? i'm not that good when it comes to dos.
stevenlee
Member level 2
uninstall linux
use your backup cd, boot to dos, at prompt, type: fdisk/mbr, doing this way, you grub boot loader is removed, but your linux is stlill there ,when you want it again,, then use your linux cd to reinstll the grub,
    nafaiz
nafaiz
Member level 5
Malaysia
Re: uninstall linux
ic...now i can proceed uninstalling it....thanks everybody
mehboob_iiui
Full Member level 2
Rawalpindi - Pakistan
Re: uninstall linux
If you want to revert back to win XP,
insert your XP boot disk and boot from cdrom , go into recovery mode , you will need your administrator password,
when you're logged in just type
C:>fixmbr
ravikrai
Member level 1
india
uninstall linux
boot up in DOS and try fdisk
louisnells
Full Member level 4
Re: uninstall linux
Are you using a boot manager from master boot record ?
If you are having boot manager on another active partition just setting the partition containing the 2nd OS will make things right.
jeremy_zhu
Member level 2
uninstall linux
fdisk /mbr and delete the linux parts by using some harddisk tool
ranaknight
Newbie level 6
Re: uninstall linux
Boot into DOS from a startup disk.
run fdisk from the command prompt.
do two things here :
1. set the windows partition as the active partition.
2. delete the linux partitions and reformat them to FAT or NTFS
(so that you can reclaim the disk space)
edacw1
Full Member level 4
uninstall linux
I think you should format the linux partition and reinstall windows.
cybersan2002
Junior Member level 3
Re: uninstall linux
Best Way is to use boot manager which comes Drive parttioning software(Partition Magic or Paragon Partition manager).
It is very easy to use.
Solves all ur booting problems,surely.
Give it a try.
Toggle Sidebar
