xilinx xsg
Hello, I'm new to using FPGAs. I currently have the ISE 10.1 suite installed including System Generator, as well as the full Matlab/Simulink Suite.
Basically, I'm trying to figure out what the latency per block is. For instance, in one example I have, a DSP48 block has a latency of 5. If that wasn't in the example, I wouldn't know how to figure that out. Is there any way that you can verify what latency you need so you can properly add your delays lines?
