[SOLVED] How to determine the Specific current of the MOS transistors in CADENCE
muffassir
Member level 3
Planet Earth
Hi all,
How to determine the specific current of the nMOS /PMOS transistors.
Specific current is given by
Is=2nuCoxVt(square)W/L
which is used in the Ids equations of the MOS in strong and weak inversions.
I want to know the procedure to find the specific current in CADENCE VIRTUOSO 6.1.4
Any help is much appreciated...
Thanks
Muffassir
Specific current is given by Is=2nuCoxVt(square)W/L
You should find µ , tox & Vt in your process specific SPICE model files, then calculate Cox from tox.
For n use values between 1.3 .. 1.5 , s. e.g. this output characteristic:
Binkley's book (cf. image above) gives reference values for all these values for different process technologies on pages 41-43 .
Hi Erikl Sir,
wow thts the book i needed the most..!!!
I got it from one of my sources and reading started also....
Thanks a lot for unconditional replies to the Posts...may *** keep you Long Live !!
Bye Tc.
can anyone send me the spreadsheets of the author BINKLEY....I cannot download them from this page:
It gives me erorr when i fill all fields and click submit !!. Please download a set and then email me at muffassir@gmail.com
Or else if u own it then pass it to me ... Its Freeware..
