Note: This feature currently requires accessing the site using the built-in Safari browser.
What do you mean by 'steps' ?
If your Standard Cell Library doesn't already contain such cells, you can build them from the primitives of your Standard Cell Library.if i want to design a multiplier and division, i will make some basic gates to connect it such as full adder, register or something.
If you really should want to develop your own Standard Cell Library, I'd suggest to generally use minimum transistor sizes, respecting the necessary driver fanout capabilities, however.Then how i determine the sizing of the transistor in the full adder or basic gates that i used??? In order to met the specification in the datasheet??
