How to determine the resistance value in flash ADC design?
Friendcheng
Junior Member level 1
hello,everyone
Iam designing a flash adc now.
To generate the reference voltages, a resistive reference ladder has to be used, and my problem is i don't know how to determin the value of the resistence.
Can anyone tell me how to determin the value of the resistence?
can anyone give me the method in detail or the paper which explain it in detail.
Best regards.
flash adc
Lower limit: power consumption
Upper limit: 1. output resistance ≪ input resistance
2. sample or conversion time > RC * n * ln2
The order of magnitude of "≪" is 2^n , n being the resolution of the converter, i.e. e.g. a factor of 1024 ≈ 1000 for a 10-bit converter. RC < 1/7 * conv_time, in this case.
Plan your resistor chain values to be as high as possible, respecting the upper limit criteria.
flash adc design
Thank you for your answer.
Can you explain the R and C in the following formaluation more clearly.
"sample or conversion time > RC * n * ln2"
and the following are my question of the above formulation
1.how does the formulation being obtained, can you recommend a paper which explain it in detail
2.does the R mean the whole resistence of the resistence chain?
3.does the C mean the whole capacitance of the preamplifiers,and it is equal to 2*Cgs*m, m is the number of the preamplifiers which connect to the resistence chain?
adc designs
hi friendcheng,
My dissertation is also to design a flash A/D-Converter. I will start this project at the end of March. HOpefully we can share our progress about this topic if you want and exchanging ideas on this if you want. Thanks
flash adc designs
R is the equivalent output (source) resistance of the resistor chain at that point where you connect this tap (eventually via a switch) to your measurement circuit (e.g. amplifier or comparator). C is the total equivalent capacitance at this very same point.
This is such basic, that you just need your standard textbook on electricity ;-)
The inequation results from the standard formula of loading a C via an R :
V = V0 (1 - exp(-t/RC)) (s. your standard textbook on electrics)
... and the requirement, that the difference between the voltage level to be measured and the voltage level attained on C (via R) be less than the required resolution :
V0 - V = V0*exp(-t/RC)
V0/(2^n) < V0*exp(-t/RC)
-n*ln2 < -t/RC
t > RC * n * ln2
No, the equivalent source resistance at the tap, for each tap point, s. above!
No, the equivalent capacitance at the tap (m=1), again for each tap point, s. above!
This means, you must respect the above inequation at every tap point of the resistor chain to the connected circuit. If the capacitance is (nearly) equal at every tap, the highest source resistance of the chain is in the (arithmetic) middle of the chain. This tap point must respect the above inequation.
HTH! erikl
    Friendcheng
    V
flash adc converter
I am very glad to exchange ideas with you.
kickbeer said:
hi friendcheng,
working of flash adc
don't forget about mismatch when going for smaller R
architecture of flash adc
hello friendcheng,
are you doing A/D converter with flash or folding architecture?
how to design a flash adc
yes
kickbeer said:
hello friendcheng,
design of a flash adc
hello friendcheng,
flash or folding?
design flash adc
hi, kickbeer
sorry for vague reply.
the architecture of the ADC i am designning now is the flash architecture.
folding and interpolation flash adc
hello friendcheng,
it's ok.Which type of comparator are using actually?
power consumption in flash adc
kickbeer said:
hello friendcheng,
I am going to design a folding and interpolating adc.I am glad to exchange idea together.:D
adc design aspects
Friendcheng said:
hi, kickbeer
Hi friendcheng,
How's your progress with flash adc?
10-bit flash adc
chinacore said:
kickbeer said:
hello friendcheng,
I am glad to exchange idea with you too
can we communicate by email?
my email is :lianlianhonghong@163.com
Added after 3 minutes:
kickbeer said:
Friendcheng said:
hi, kickbeer
Hi friendcheng,
formaluation
how to design poly metal capacitor layout
