How to determine the memory needed for HFSS simulation?
Boomerang
Newbie level 6
USA
site:www.edaboard.com hfss memory error
Please can someone tell me how to determine the required Memory size needed when setting up a simulation in HFSS. For some reasons, the program keeps stopping in the middle of simulations and returning "...insufficient memory" error message. Thks.
hamidmoghaddas
Member level 1
Re: HFSS memory
hi
while simulating you will find two problems regarding the memory. firstly , the simulation time . with 512MB ram and 2 GB free hard some of my simulations lasted 2hours 30 minutes.
secondly , at the middle of simulation stop happens because of insufficient VIRTUAL MEMORY.
to solve the problems::::::::::
1 try to have enough mem on your hard disk in drives which you have installed hfss and your system drive.
2 have fast and enough RAM ::: 1GB is suitable of the mark and model DDR400
good luck
Dillon
Junior Member level 2
Re: HFSS memory
>512M
kevinj
Re: HFSS memory
I was getting this problem somtimes. To fix it, I changed my sweep from fast to interpolating and decreased the radiation box to just over a quarter wavelength in size around the object. The interpolating sweep just gives better results and doesn't take much more time. kj.
faghani
Member level 3
NO HIDDEN ADVERTISEMENTS
Re: HFSS memory
u can set the temporary folder of ur user on another partition which has more free space, to do this goto control panel | system | Advanced Tab | Enviornment Variables
change the user variable and system variable for TEMP and TMP to wherever u have more space.
then goto HFSS | Tools | options | general options
and change the temp directory to that folder.
u can do step 2 without doing step 1 if your temp folder is not located on the full partiotion. that's obvious !:D
