imtiaz369
Member level 2
I recently simulated a horn antenna in HFSS using the WR-28 waveguide. As we know, the WR-28 waveguide has its TE10 mode cutoff frequency at 21 GHz, and the next mode cutoff frequency at 42 GHz. To evaluate the bandwidth of my horn antenna, I ran a frequency sweep from 1 GHz to 70 GHz.
And my observations:
- The S11 parameter appears to be very stable and consistently around -20 dB starting from 21 GHz.
- The gain is above 15 dB across the entire frequency range after the cutoff frequency.
Questions:
- Is my assumption about higher-order modes affecting the results correct?
- How can I effectively filter out the higher-order modes to observe the performance of the fundamental mode only?
- Is there a recommended method or metric to precisely determine the practical bandwidth of my design in a simulation?
