Right click on the Material Icon (ie test_mat) and select properties to get to material property window.
Select the tab for "Material Filters"
Change radio button selection to "All Products"
Go back to "Materials" tab
select the material that you would like to input a mass density and enter it
Once the Mass Density is specified, you can actually plot the Local SAR, Average SAR, or IEEE SAR (cell phone applications). Note that you should read the help concerning the deifference between Local (fast) and Average (slow) SAR. The average SAR involves many incremental integrations of SAR in a given unit mass spheres.
You will have to do this each time you enter the material properties window, and also, there are many common materials whose thermal properties, including mass density, are already available. Once you have turned on the "all products" option, you can see these properties of many of the materials in HFSS.
Hope this helps!
