hi.
the busy tone is periodic and has a determined time for make and preak ( usually 0.5 sec. and 0.5 sec.) (may vary from country to another)
so, u have to detect the voices in the telephone line and convert it to logic signal (0 and 1 ) ( if u use a microcontroller) then u can sample this signal, then if this signal has the time properties like standard busy tone so u detect the busy tone.
you have to chek it 3 or more times to avoid errors
It looks like Q.35 does define the busy tone parameters , but dont believe to that - operators sometimes can change tone defaults from standard to something their managers love tro hear).
I witnessed that few times
For all measurements you should define smallest time interval to detect noise to decode tone pulse pattern . Let say, we can approach 100-200 milliseconds .
Actual implementation could vary dependent on what quality extend you are willing to achieve
a. Simplest :
You can implement simple comparator connected to to your telepone pair (AC bypass ) and count number of zerocrosses - that will give you frequency of signal in line .
b. Improved :
use 1 bit Goertzel algorithm to detect frequency . A lot of implementations do exist . There is some explanation :
c. Better than above :
Implement digital filter in PIC to detect narrow frequency (band pass filter) and use filtered data for detection . Let say atmel has an application note http://www.atmel.com/dyn/resources/prod_documents/doc2527.pdf
where second order band pass filter on mcu is described. You should find one which is applicable to PIC.
Using above methods you will have a sequence of bits or tone pattern - duration of tone and pause . This is to be matched towards your operator's used tone pattern , which has to be apriori analysed and stored into your program .
This document could be useful but it is little bit complicated:
At the end , i suppose seaching google will help to find ready to use solution already available,
but i leave this opportunity to you)
