How to detect red color ball with a if statement in MATLAB
umagon
Newbie level 3
as the title above, i wanted to write a code if red color ball was detected, the led will lit on (in MATLAB). how to write a IF statement to make sure the red ball was detected from the webcam? and how to determine the range of RGB value
let say i have a variable A = a ball bound in a box, then by using a IF, if the ball that bounded in the box (variable A) is red, then led will on
please help, thanks alot
Since you are using a webcam, not all adapter would give the same RGB result for a single color. They might be just the same but they may vary by a point or so which makes detection of color very difficult. Hereby you have to go for a check of the red color ball for its corresponding RGB value. You may say this as a training phase.
aqVideo = videoinput('winvideo', 1, 'RGB24_640x480');
preview(aqVideo);
In the preview screen, place the ball close to the camera with decent focus such that the major part of the picture is covered by the ball.
aqImage = getsnapshot(aqVideo); // This will acquire the image/snapshot.
Once done calculate the RGB values of the pixel which appears the most.
Regards,
Devilwar
