How to detect interrupt pin?
d@nny
Full Member level 5
hell0!
when iterrupt on INT RB0 occurs it goes of 04 location. Is all the 4 interrupt pins in pic16f84 goes to same position if yes than how to detect on which pin interrupt occurs? or i nee to read the pins in interrupt routine
thanking you in anticipation
only pin INT0 RB0 have interrupt. no other pin.
You can recognise the interrrupt source for the flag at the register.
You have two different Interrupts available on Port B.
RB0 which can detect the signal change / transision from high to low or low to high and is reported by the INTF bit.
RB4-7 can detect a change of state from 1 to 0 or 0 to 1 on any of those 4 bits and is reported by RBIF.
Not aware that the ISR can tell you which of those 4 bits has changed, you would have to do that with your own coding by saving the current state of PortB, before activating the Interrupts, and comparing it with the new state of PortB when RBIF / the ISR is activated.
