[SOLVED] How to detect direction of a rotary encoder?
hafrse
Full Member level 3
Full Member level 3
Need some advice on how to build a circuit that generates short to GND only when the encoder is rotated clockwise by using the CLK and DT outputs, the square wave pluses generated from the encoder will be feed into a pitch control circuit (Pitch CLK P1.jpg) together with the grounded detection when the encoder is rotated clockwise (Pitch DIR P2.JPG)
Thanks!
The inputs I have in this vintage device (tape recorder) is Direction detect (Ground when the encoder is rotated clockwise) and clock input (please see the previous images)
--- Updated ---
May be the Pitch Direction is actually to be connected to the DT output of the encoder. Will try that tomorrow
There should be a 90-degree phase difference between CLK and CLKBAR signals in Optical decoders. Leading Phase or Lagging Phase give Rotation Direction.
Sounds like you obtain digital output... Yet maybe if you convert to an analog waveform, here's a dirt-simple rising-falling detector to tell you what direction it's going. Values need adjusting to desired response.
--- Updated ---
Link runs my schematic in Falstad's animated interactive simulator:
tinyurl.com/2dc56con
    hafrse
Solved, just connected the CLK output to the Pitch CLK input and the DT output to the Direction DET input :)
LaTeX Commands Quick-Menu:
