How to detect a plug is connected to socket
bobdxcool
Member level 5
I have a plug and socket. Before I turn on power supply from a contactor, I need to detect if the plug is connected to the socket via a microcontroller. Any ideas on how to do this ?
The Plug I am using is
The socket I am using is:
All the four pins of both socket and plug are connected to neutral, ground and (120v) ac lines.
The issue is that all the four pins of both socket and plug are connected to neutral, ground and (120v) ac lines. Please see the pictures posted above. So, there are no other pins left to use. I was thinking of using a magnet near the socket and a hall sensor stuffed (Not a safe idea I guess) somewhere near the plug. Any better ideas ?
acannell
Junior Member level 2
You cant detect the presence of mains or ground as a way of proving the connection is there?
FvM
Super Moderator
Staff member
Bochum, Germany
I count 3 pins being used
Yes. And bobdxcool would have a hard time to fit the blue 4 pin connector with the yellow 3 pin panel mounted inlet. :)
I believe that's just a wrong photo. Also the terms plug and socket are apparently mixed up.
There's no provision for pilot contacts in the pinout of standard CEE connectors below 63 A. Special versions of wall mounted receptacles with built-in pilot switch are available from some manufacturers.
What do you want to achieve? Do you want to power the wall mounted inlet (yellow part)? That would be in fact against all safety rules.
