please give me some advice on how to design VCO buffer.i desined a 4~8GHz VCO without buffer desined in 2um HBT process.,it works well,but I need a 4~8GHz VCO buffer.is a attenuator needed? i don't think insert a attenuator between VCO and the buffer is a good idea in MMIC,is that wright? why so many VCO papers never discuss VCO buffer? thanks.
The choice of to add a buffer amp or not depends on two things:
1) If you need higher power (> perhaps 5 dBm), you will need the buffer amp.
2) If the impedance of the load changes, like in a sp2t switch going to two locations, then the VCO will jump in frequency/phase, and if you can not take the jump, then you will need isolation. The amount of isolation will dictate how many buffer amplifier stages and attenuator pads are needed.
