How to design the the following operation
EHY
As i attach the image, I want to design the circuit like SR-latch but quite different.
If the rising edge of S signal is high, output Q is high(set)
Otherwise, if the rising edge of R signal is high, output Q is low(reset).
output Q of conventional SR-latch using nor gates is low when S and R is high (S=1,R=1)
I don't want this operation.
I just want circuit. the rising edge of S and R controls output signal Q.
plz help me`~:cry:
Instead of using fli flops you could use combinatorial solution:
Q = C AND !R
Two resistors and a bjt is sufficient
Q = C AND !R
Thank you but, What is solution using Flip Fliops?
How to design the following operation??
I want to design circuit
when the rising edge of signal S is triggered, then output Q is high(set)
and when the rising edge of Signal R is triggred, then output Q is low(reset)
(edge triggered SR-flip flop ?!)
I don't want combinational logic , Q=S and ~R
plz help me~
Re: How to design the following operation??
The edge triggered Flip Flop may be designed using gates is also called a Type II Phase Detector.
Either it is level sensitive or edge sensitive.
It is impossible to do without Logic. What are your real constraints?
i want operation of the attached image
i can´t imagine a dual clock triggered flipflop.
What´s wrong with the combinatorial solution? Is it too easy?
because simple cmos gate logic has process speed limitation
so i have to implement such CML type circuit
What about if R precedes S?
If rising edge of R signal is trigerred firstly, the output Q is just low
and then if rising edge of signal S is trigerred , the output Q is high
