wjxcom
Full Member level 5
- Joined
- Sep 7, 2005
- Messages
- 284
- Helped
- 4
- Reputation
- 8
- Reaction score
- 3
- Trophy points
- 1,298
- Activity points
- 3,868
Hi all: I am designing a 10bits 50MHz PipelineADC, the common voltage is 1.65V, the possive reference voltage is 1.9V and the negative voltage is 1.4V.
the wave of 1024 points fft is shown below:
But there have some wrong with this circuit:
1, In the SampHold circuit, the output of SampHold circuit SHN and SHP. From the simulation result, I find that the common voltage in sample phase and in amplify phase is different. the simulation result is shown below:
2. In the 8th stage, the output of 8th stage is VON8 and VOP8. From the simulation result, I find that the common voltage in sample phase and in amplify phase is different. the simulation result is shown below:
3. The result of VON8-VOP8 is strange! from the wave of VON8-VOP8, I found that at the beginning of the simulation, the valut of VON8-VOP8 is 170mV, then the valut of VON8-VOP8 becomes smaller step by step, and at the end of the simulation, the value of VON8-VOP8 is about 127mV. the simulation rusult is shown below:
**broken link removed****broken link removed**
I think the size of switch is not designed carefully which causes these problems. But I do not know how to design the switch? Help me please, thax!!
My be I need to upload my circuit, then somebody can simulate it.
