How to design step-up/step-down DC-DC Converter (2V to 100V)
bctang
Junior Member level 2
DC-DC Converters
How to design step-up/step-down converter accepts 2Volt to 100Volt inputs?
I need to design Step-Up/Step-Down DC-DC Converts 2Volt to 100Volt input to a 12V output at up 2A. The output voltage can always maintain 12Volt. :cry:
Thank You
Re: DC-DC Converters
8) A very complex requirement.
very difficult in standard buckboost topology, try cascading differant converters with switching logic to switch a single dc dc converter depending on the input voltage..
:? A costly proposition..
Hi, rauol
First i need to say thank you for your suggest.
i known this is very difficult, because i am doing my project Design Micro Hydro System. My voltage from generator is variable it can generate up to ~70Volt. So that i need to step-down my voltage to charge my battery 12Volt. if the generator is runing at low rpm the generator generate low voltage about 2~11Volt. the my dc-dc converter need to boost up to 12Volt.
Can u try to explain more detail about the design because i need the low cost design?
Thank You.
Thank You
I do not think there is choice for you but to use switch mode power supply design.
Thank You
Do you have any idea for this "switch mode power supply design" ?
i have found out from internet:
"http://korea.maxim-ic.com/appnotes.cfm/appnote_number/227"
but this design is no functioning because i already testing. if increased input Vin to 4.35V. DMM at point 8 dropped to 1.69V, IC MAX761 getting hot.
zkai2000 said:
bctang said:
Thank You
Do you have any idea for this "switch mode power supply design" ?/quote]
Im agreed with djalli..try using switch mode power supply. :)
Do you have any idea how to design "switch mode power supply design". Pleas help me.... :cry:
8) Do u really require 2 volt minimum input. can your micro generator supply around 15 Amp at 2 volt. a realistic one would be from 15 to 100 volts
I am using "Permanent Magnet DC Motor" as my dc generator because my project just a demo unit. So that, i need the generator generate the voltage at low RPM. My generator generate the voltage is depend the turbine spin.
My generator can produce very high voltage but the current i no think so can produce until 2Amp. Because i think this is depant the load.
So, i need to control the voltage to fix and always maintain to 12Volt to charge my battery. I am using "Lead Acid Battery" 12Volt. :(
