How to design low-frequency multiplier
microelek
Member level 2
low frequency multiplier
how to design PLL circuit?
20Hz-20Khz multiplier with 360.
I use 74HC4046 and CD4059,It not work!!
Help me design with other IC.
frequency multipleir using 74hc4046
Although I have not built such multiplier for low frequency, I found two such topics at h**p://users.otenet.gr/~athsam/frequency_multiplier.htm and on the last page of the paper at h**p://zebu.uoregon.edu/~rayfrey/431/lab5_431.ps ---there you may find some hints on the loop filter and the counter is a 4040 IC.
This same text in pdf format (and not postscript) can be downloaded from h**p://zebu.uoregon.edu/~rayfrey/431/lab5_431.pdf
By combining it with a preamplifier from the first url you may have success.
Regards, unkarc
