How to design envelope detector in analog IC?
guest3
envelope detector ic
The carrier frequency varies from several KHz to several Meg Hz, and the envelope is very low speed, kilo Herz and maybe even less. How do I design the
detector in analog? The signal is differential. Thank you.
jiripolivka
Advanced Member level 5
Santa Barbara
As you do not indicate the power level, your detector can be either a simple diode with a 50-Ohm matching resistor at input, and a 100 kOhm load resistor at output. Such detector would need -10 to 0 dBm to operate well.
If you need to detect power levels from < -40 dBm, there are many "logarithmic" detector ICs by Analog Devices (AD83xx series), Maxim, Linear Devices, and Hittite.
I used some of them, AD83xx series often works from almost DC to >1 GHz. Check the specifications and request samples.
Concerning the differential signals, the AD83xx series has differential inputs; otherwise use a resistor voltage divider to get a single-ended input signal.
upvl
Junior Member level 3
US
Re: envelope detector ic
Dynamic range is a critical specification for envelope detector, which will determine the topology.
