How to design DPLL? Request for resources
cslover
Junior Member level 1
DPLL
How to design DPLL. if you have doc about DPLL, please send it to me .
Thanks advance.
Hi
You can look at :
h**p://w*w.actel.com/documents/s04_18.pdf
Reactions: yezwe
    yezwe
I am very interested in this topic too.
Any more in-depth info ?
Hi
There is also this ap note from Texas Inst.
h**p://www-s.ti.com/sc/psheets/sdla005b/sdla005b.pdf
A DPLL is consist of 3 parts typically:pD,K counter and the I/D divider.
PD:phase detector, is used to detect the phase difference between the incoming signal(Ref Frequency) and the output of the DPLL(fedback from the output); PD will output the up or dn signals to indicate the phase difference.
K counter functions as a loop filter,it will output a carry or borrow pulse when the counter equal to the predefined K, and the counter is gotten via sampling the up/dn signals output from PD.
I/D divider is a controlled divider.It will output a central frequency by dividing a particular number. However, the division ration will be controlled by the carry/borrow pulse from the K Counter.
the output of the I/D divider will be feed back to the PD.
Then a phase locked LOOP is constructed!!
I have just finished demo,the most difficult thing is programmable frequence generation,The PD can be finded at @ltera,it is good.but i have not find a good way to know whether the verifying freqence is the same of the reference
