Hello Everyone;
In some PLLs, active low pass filter is used. How can we design the active filter (that contains op amp) without negative power supply?
you are actually feeding the output of the lowpass filter to the VCO in a PLL and so if the VCOs input is always positive then it means the output of the active filter is gonna be positive and hence no negative supply would be needed....
