How to design a USB charger for mobile phone?
shaw
Newbie level 5
USB charger
Hi,All:
I need to design a USB charger for mobile phone. Anyone has experience about that?
dll_embed
Re: USB charger
I've seen a very simple USB charger. It just links the 5V directly to HP. No circuit needed. And it works well!
regards
electronrancher
Advanced Member level 1
i would use a real charger IC, nim-h get really screwed up without current limit and overcharge limit.
as long as the charger doesn't pull more than 500mA (the usb limit i think) any one should be fine. switchers are better than ldo, but it's up to you. try the maxim or linear tech sites
bogdanm
Re: USB charger
Check this link:
hxxp://www.maxim-ic.com/quick_view2.cfm?qv_pk=4002&ln=
It's an integrated charger from Max*m; if this is not what you need check their products, they have other USB-based chargers.'
Taro
Full Member level 2
Is this method harmful to USB port?
Does it damage USB port?
wacksbaby
Newbie level 1
Philippines
Re: USB charger
I have read an article regarding USB universla phone charger in the EDN online magazine. It uses an IC produced by Linear Technologies. I forgot the part number, it starts with LT?????. Connecting directly to the USB port may damage your phone or the port especially if it draws more than the said capacity.
