Hi!
I'm trying to design a smartcard reader for asynchronous cards (protocol T=0) and for synchronous cards (protocol S=9 as SLE4428 and protocol S=10 as SLE4442) with a PIC microcontroller, but I don't know how to implement really this, because all two prococoles uses different clock and protocol.
Then I need suggestions about the implementation, for synchronous, can be used a SPI peripheral if it is complemented with any I/O pin? For asynchronous, the power is using UART peripheral, but the uC must make the clock for card, then, how can I make this clock? And, how can I combine all two protocols using the same pins?
Thanks in advance
Regards,
