How to design a divider by 15.8 ?
AdvaRes
At home
Hi members,
Please help.
Re: Divide by 15.8
What is your target technology? FPGA? In FPGA dividing by 15.75 is much easier. would you like to describe it?
    AdvaRes
Divide by 15.8
The target is a Frequency divider for PLL.
Divide by 15.8
if you dont care the clock jitter, the most easy way is to divide the source clock by 15 and 16 alternately.
For example:
15.8 = 15*0.2+16*0.8, you can divide 20 source cycle by 15, then 80 source cycle by 16, then repeat...
Re: Divide by 15.8
AdvaRes said:
Hi members,
Please help.
I havent tried it because right now i have no time, but one possible way way i think you can do is : " Write a C++ program to approximate the inverse of 15.8 by the series of power of 2 with integer coefficients". After that, just shifting and multiplying. Hope my idea is not wrong.
Re: Divide by 15.8
You should multiply your frequency by 5 and then divide by 79. You will have a divide by 17.8. If you use FPGA DLL you can use this approach. First multiply by 4 and then divide by 63. then you will get a divide by 15.75.
