How to design a comparator N-bit with lowest cost?
win3y
Member level 1
Hi everybody;
Is there any way to design a comparator N-bit with lowest cost?
The comparator I made as following:
input [N - 1:0] INP0, INP1;
output [N - 1:0] MIN;
assign MIN = (INP0 < INP1)? INP0:INP1;
I wish to make another comparator that occupies smaller hardware cost.
Thanks.
W3Y.
win3y said:
Hi everybody;
Thanks.
W3Y.
There can be another way of implementing N bit comparator.
So 3 possibility will be there in the magnitude comparator
a) INP0 = INP1
b) INP0 > INP1
c) INP0 < INP1
a) INP0 = INP1
PI (INP0 xnor INP1) i ranging from 0 to N-1
so for 4 bit number , INP0 = INP1 if
(INP0[3] xnor INP1[3]) and (INP0[2] xnor INP1[2]) and (INP0[1] xnor INP1[1]) and (INP0[0] xnor INP1[0]) = 1
b) INP0 > INP1
(INP0[N-1] and ~INP1[N-1]) or [(INP0[N-1) xnor INP1[N-1]) and (INP0[N-2] and ~INP[N-2])] or [(INP0[N-1) xnor INP1[N-1]) and (INP0[N-2) xnor INP1[N-2]) and (INP0[N-3] and ~INP[N-3])] or ..
C) INP0 < INP1 ,
(~INP0[N-1] and INP1[N-1]) or [(INP0[N-1) xnor INP1[N-1]) and (~INP0[N-2] and INP[N-2])] or [(INP0[N-1) xnor INP1[N-1]) and (INP0[N-2) xnor INP1[N-2]) and (~INP0[N-3] and INP[N-3])] or ..
I am not very sure , if you code the above comparator logic using verilog , how much difference will be with your code, as per the hardware consumption is concerned.
You can try my logic and synthesize the verilog code and check the result.
I think this may reduce the hardware cost , as the outcomes in every stages are pre-calculated
Please let me know the result..
Thanks
Deb
Π
    win3y
Thank you for your post. I also vote "helped" for you.
This time I am doing something to reduce the hardware cost, not only these comparators.
W3Y
