How to delete the copper plane (Top or Bottom) on Protel 9?
mkbs
Member level 3
Help on copper plane
Hi to all,
I need help !!!
how I can delete the Copper plane (Top or Bottom) on Pr@tel99SE.
I have seen that I can't delete planes all together.I have tried with Select --> Connected copper but I can' t deleted the selected copper.
Tanks in advantage
MKBS :(
pisoiu
Advanced Member level 3
Romania
Re: Help on copper plane
You can delete any object from top and bottom with edit/delete. Just make sure it is not locked. Keyboard shortcut: "e" then "d".
/pisoiu
House_Cat
USA
PR0TEL won't let you delete a layer that still has primatives on it. To get rid of all the lines, arcs, strings, etc. on a layer that you want to delete - first deselect everything by doing a hotkey 'X' 'A' (deselect all); now go to the layer you want to get rid of (tab to it on the bottom of the screen); select everything on the layer by doing a hotkey 'S' 'Y' (select all on layer); put your cursor on one of the elements of the layer and do hotkey hold 'shift' and press 'delete'. Now you can delete the layer from your stackup.
EEHardware
maybe you have fixed it !!
first , unfix it , and use edit/delete !
