How to define an internal clock in DC?
liwei039
Newbie level 6
clock mux
I just want to define an internal clock in DC. this clock is come from a mux of two input clock then through a combination logic.
should be use create_generate_clock? how to use it?
aravind
Advanced Member level 1
india
yep use create_generated_clock command
hfooo1
Member level 1
the two clocks work coinstantaneously or not?
in either situation i dont think it's needed to define a clock.
dcreddy1980
Full Member level 5
Munich, Germany
As you said, the clock is an output of mux, basically i would use a case analysis on the select signal and select which ever clock u want for the optimization, its a better scenarion in your case.
if you have two clocks lets say clk_a and clk_b as inputs to mux, clk_a is connected to select(0) pin of mux and clk-b is connected to select(1) of mux, if you want to optimize the block with worst scenarion where u feel the block can be made robust, then select a high speed clock.
set_case_analysis 0 [get_ports select]
// assumed mux select to be input or define the hierarichal path and now ith above command, it will select clk_a for the analysis
dechen
Junior Member level 2
sometimes you may want to define a new clock at the mux output, so a new clock tree can start from the new clock. For synthesis it does not a difference, but it maybe useful for clock tree synthesis.
