How to decode a text stream in C
techie
Advanced Member level 3
Pakistan
text stream decode
I have a text stream as follows.
Blah blah blah blah ....
Parameters:"misc text"
Timer:"12345"
blah
blah
I want to read them into string variables like ID = "ID string" etc. Can someone tell me a simple way to do that in C.
you can use fgets go read a file line by line. then, you can get the word until ':' and choose the appropriate action. for instance, if the first word is ID, then the rest after ':' should be copied to the string id.
Isn't there a "scanf" type function to do that
sscanf would work...
It's in stdio.h
<# of items formatted> = sscanf(<source string>, <format string>, <target 1>, <target 2>, ...);
In your case, I think the target string is: "%s:\"%s\""
I could be wrong, though...
- Nobody
Can I write
sscanf(string,"\r\n%s:\"%s\"\r\n%s",dummy1,IDstring.dummy2);
Something like that would work. You just need to play around with the format string.
- Nobody
